Zum Hauptinhalt wechseln
Moto G4 Midframe Replacement
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. Moto G4 Midframe Replacement, Back Cover: Schritt 1, Bild 1 von 3 Moto G4 Midframe Replacement, Back Cover: Schritt 1, Bild 2 von 3 Moto G4 Midframe Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port.
    • Gently twist or pry to open a small gap between the back cover and the body of the phone.
    • While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
  2. Moto G4 Midframe Replacement: Schritt 2, Bild 1 von 2 Moto G4 Midframe Replacement: Schritt 2, Bild 2 von 2
    • Slide your tool all along the side of the phone to separate more of the clips securing the back cover.
  3. Moto G4 Midframe Replacement: Schritt 3, Bild 1 von 3 Moto G4 Midframe Replacement: Schritt 3, Bild 2 von 3 Moto G4 Midframe Replacement: Schritt 3, Bild 3 von 3
    • Keep your tool inserted slightly under the back cover, and slide it around the top corner.
    • If necessary, continue prying around the remaining edges of the phone until the back cover comes free.
  4. Moto G4 Midframe Replacement: Schritt 4, Bild 1 von 2 Moto G4 Midframe Replacement: Schritt 4, Bild 2 von 2
    • Remove the back cover.
    • To install the back cover, carefully position it over the phone and then press gently all around the edges until you feel the clips snap into place.
  5. Moto G4 Midframe Replacement, Midframe: Schritt 5, Bild 1 von 3 Moto G4 Midframe Replacement, Midframe: Schritt 5, Bild 2 von 3 Moto G4 Midframe Replacement, Midframe: Schritt 5, Bild 3 von 3
    • Push to eject and remove the MicroSD and SIM cards (if installed).
  6. Moto G4 Midframe Replacement: Schritt 6, Bild 1 von 2 Moto G4 Midframe Replacement: Schritt 6, Bild 2 von 2
    • Use a spudger to pry up the rubber cover for the camera flash connector.
  7. Moto G4 Midframe Replacement: Schritt 7, Bild 1 von 1
    • Remove the rubber cover.
  8. Moto G4 Midframe Replacement: Schritt 8, Bild 1 von 2 Moto G4 Midframe Replacement: Schritt 8, Bild 2 von 2
    • Use a spudger to disconnect the camera flash connector by prying it straight up.
  9. Moto G4 Midframe Replacement: Schritt 9, Bild 1 von 1
    • Use a T3 Torx driver to remove the nineteen identical 3.1 mm screws securing the midframe.
  10. Moto G4 Midframe Replacement: Schritt 10, Bild 1 von 1
    • Insert a spudger under the midframe at the top left corner, and gently twist to separate it from the body of the phone.
  11. Moto G4 Midframe Replacement: Schritt 11, Bild 1 von 1
    • Remove the midframe.
Abschluss
Jeff Suovanen
427.892 Reputation
259 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.757 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 67
