Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This guide will teach you how to remove the device's fingerprint sensor.
  1. Position the opening tool under the lid of the screen. Slide the opening tool around the edge of the screen to loosen the adhesive.
    • Position the opening tool under the lid of the screen.
    • Slide the opening tool around the edge of the screen to loosen the adhesive.
  2. Lift the screen off the body  from the top.
    • Lift the screen off the body from the top.
  3. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  4. To disconnect the screen from the body, stick the spudger under one of the corners of the gold tab. Lift up, removing the tab from the device.
    • To disconnect the screen from the body, stick the spudger under one of the corners of the gold tab.
    • Lift up, removing the tab from the device.
  5. Pull the screen up to fully remove it.
    • Pull the screen up to fully remove it.
  6. Insert the tweezers under the metal backing of the sensor. Lift up the backing until it is detached from the phone.
    • Insert the tweezers under the metal backing of the sensor.
    • Lift up the backing until it is detached from the phone.
  7. With the tweezers, grab the black connector located just above the fingerprint scanner. Pull the connector to the right until it is detached from the phone.
    • With the tweezers, grab the black connector located just above the fingerprint scanner.
    • Pull the connector to the right until it is detached from the phone.
Abschluss
Miriam Lam
1.053 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S2-G2, Livingston Winter 2018 Mitglied von Cal Poly, Team S2-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G2
4 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 2
Insgesamt: 296
