Zum Hauptinhalt wechseln
Motor and Cord Replacement
Was du brauchst
  1. Motor and Cord Replacement, The Motor and Cord: Schritt 1, Bild 1 von 1
    • Remove the highlighted screws shown with a Phillips #2 Screwdriver.
  2. Motor and Cord Replacement: Schritt 2, Bild 1 von 1
    • Remove the motor from the motor mounting plate. Pull the motor and cord to the side.
  3. Motor and Cord Replacement: Schritt 3, Bild 1 von 1
    • Use pliers to grip the crimp.
  4. Motor and Cord Replacement: Schritt 4, Bild 1 von 1
    • Open the crimp by pressing it opposite to how the crimp was pressed. Repeat for second crimp.
  5. Motor and Cord Replacement: Schritt 5, Bild 1 von 1
    • Remove the crimps from the wires by pulling them off.
  6. Motor and Cord Replacement: Schritt 6, Bild 1 von 1
    • Untwist the brown and the silver wire by gripping the tip and unwinding them. Do the same for the second wire.
  7. Motor and Cord Replacement: Schritt 7, Bild 1 von 1
    • Separate the cord and motor.
    • Now, depending on whether the cord or the motor was broken, head to the device page to order a new one.
Abschluss
Kamal Taha
679 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 1-3, Sullivan Fall 2015 Mitglied von USF Tampa, Team 1-3, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G3
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 3,083
