Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Einleitung
This guide shows how to remove the Motorola 120c battery.
  1. Hold the phone and pull the back latch down towards the bottom. Remove the back panel by releasing the latch and lifting from the top.
    • Hold the phone and pull the back latch down towards the bottom.
    • Remove the back panel by releasing the latch and lifting from the top.
  2. Remove the battery by pushing the bottom end towards the top, then lifting up. Remove the battery by pushing the bottom end towards the top, then lifting up. Remove the battery by pushing the bottom end towards the top, then lifting up.
    • Remove the battery by pushing the bottom end towards the top, then lifting up.
Abschluss
Megan Elrod
7 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 6-21, Amido Spring 2012 Mitglied von Cal Poly, Team 6-21, Amido Spring 2012
CPSU-AMIDO-S12S6G21
4 Mitglieder
14 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 4
Insgesamt: 664
