Einleitung
Replacing the battery for the Motorola V750 Adventure can be an easy process. With a simple snap of the cover and battery, a new one can be replaced in seconds.
Was du brauchst
Turn phone so the back panel is facing up. Then proceed to locate the latch at the top, above the Verizon logo.
Turn the phone over so that the battery text is facing right side up. With a spudger, lift from the bottom of the battery until it disconnects.
With a new battery, put into battery slot top end first, then push down with finger to secure battery.
