Einleitung
This guide will enable you to remove the antenna in a Motorola Atrix 4G.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Spudger$3.99
Insert a spudger into the small notch at the base of the battery.
Lift the battery out of the phone.
In diesem Schritt verwendetes Werkzeug:T5 Torx Screwdriver$5.49
Remove the four 5.0 mm T5 Torx screws using a T5 Torx Screwdriver.
Remove the three 5.5 mm T5 Torx screws using a T5 Torx Screwdriver.
In diesem Schritt verwendetes Werkzeug:iFixit Opening Tool$1.99
Lift up the black rubber flap using an opening tool.
Remove the single 5.5 mm T5 Torx screw using a T5 Torx Screwdriver.
Gently lift the tabs located at the top of the phone using an opening tool.
Gently lift the tab located at the bottom of the phone with the same tool.
Insert an opening tool between the front and back of the case.
Slide the tool down the side of the phone.
Repeat the same process for the other side.
Slide an opening tool beneath the antenna and lift straight up from the motherboard.
Ease the antenna from out of its guide along the side of the phone
Remove the back case and the antenna from the phone.
5 weitere Personen haben diese Anleitung absolviert.
