Zum Hauptinhalt wechseln
Motorola Buzz ic502 Screen and Speaker Replacement
Was du brauchst
  1. Motorola Buzz ic502 Screen and Speaker Replacement, Battery: Schritt 1, Bild 1 von 3 Motorola Buzz ic502 Screen and Speaker Replacement, Battery: Schritt 1, Bild 2 von 3 Motorola Buzz ic502 Screen and Speaker Replacement, Battery: Schritt 1, Bild 3 von 3
    • First flip the phone over.
    • Then find the back release circled in red.
  2. Motorola Buzz ic502 Screen and Speaker Replacement: Schritt 2, Bild 1 von 2 Motorola Buzz ic502 Screen and Speaker Replacement: Schritt 2, Bild 2 von 2
    • Carefully remove the back using the release.
    • Lift from the bottom!
  3. Motorola Buzz ic502 Screen and Speaker Replacement: Schritt 3, Bild 1 von 3 Motorola Buzz ic502 Screen and Speaker Replacement: Schritt 3, Bild 2 von 3 Motorola Buzz ic502 Screen and Speaker Replacement: Schritt 3, Bild 3 von 3
    • Lift the battery from the right side.
    • After the battery has lifted about a 45 degree angle remove from phone.
  4. Motorola Buzz ic502 Screen and Speaker Replacement, Screen Assembly: Schritt 4, Bild 1 von 3 Motorola Buzz ic502 Screen and Speaker Replacement, Screen Assembly: Schritt 4, Bild 2 von 3 Motorola Buzz ic502 Screen and Speaker Replacement, Screen Assembly: Schritt 4, Bild 3 von 3
    • Remove all six screws
    • The two top screws here
    • The two middle screws here.
    • And the two bottom screws here, they are covered by plastic pieces that first must be removed with the nylon Spudger.
  5. Motorola Buzz ic502 Screen and Speaker Replacement: Schritt 5, Bild 1 von 3 Motorola Buzz ic502 Screen and Speaker Replacement: Schritt 5, Bild 2 von 3 Motorola Buzz ic502 Screen and Speaker Replacement: Schritt 5, Bild 3 von 3
    • then carefully lift the front off the phone.
    • Marked wire will have to be solderd when re-connecting new screen
    • Speakers are connected to the screen here.
Abschluss
To reassemble your device, follow these instructions in reverse order, soldering wire onto new screen.
Austin Quinn
401 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 6-6, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 6-6, Martin Fall 2016
UMASSD-MARTIN-F16S6G6
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 118
