Ersatzteile
Kein Ersatzteil erforderlich.
  1. Begin by flipping your phone over so that the back cover is facing up. Apply force to the back cover and simultaneously slide the cover down. Note: Applying pressure on the ridges will make it easier to remove the cover.
    • Begin by flipping your phone over so that the back cover is facing up.
    • Apply force to the back cover and simultaneously slide the cover down.
    • Note: Applying pressure on the ridges will make it easier to remove the cover.
  2. Press the button labeled "PUSH" located at the bottom back of the phone. This will release the battery. Lift and remove the battery. Lift and remove the battery.
    • Press the button labeled "PUSH" located at the bottom back of the phone. This will release the battery.
    • Lift and remove the battery.
  3. Do not bend or scratch the SIM card. In addition, keep it away from static electricity, dust, and water. Gently slide the SIM card out and lift to remove it from the phone. Gently slide the SIM card out and lift to remove it from the phone.
    • Do not bend or scratch the SIM card. In addition, keep it away from static electricity, dust, and water.
    • Gently slide the SIM card out and lift to remove it from the phone.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Use a Torx T-5 screwdriver to remove the screws on the back of the phone. The screws are 6.86 mm long and 1.61mm in diameter. The screws are 6.86 mm long and 1.61mm in diameter.
    • Use a Torx T-5 screwdriver to remove the screws on the back of the phone.
    • The screws are 6.86 mm long and 1.61mm in diameter.
  6. Slide a pry tool underneath the adhesive rubber stip and peel it back away from the phone. Repeat for the other side Repeat for the other side
    • Slide a pry tool underneath the adhesive rubber stip and peel it back away from the phone.
    • Repeat for the other side
  7. Insert the pry tool in the slit on the side of the phone and slide it down until you hear an audible click and the phone bottom loosens from the top. Use the pry tool to release the two hooks on each side and the two hooks at the top holding the case together. Release a total of six hooks from the sides and top to free the phone into two halves.
    • Insert the pry tool in the slit on the side of the phone and slide it down until you hear an audible click and the phone bottom loosens from the top.
    • Use the pry tool to release the two hooks on each side and the two hooks at the top holding the case together.
    • Release a total of six hooks from the sides and top to free the phone into two halves.
  8. Using a Torx T-5 screwdriver remove the screws at the top of the phone. The screws are 6.86 mm long and 1.61mm in diameter. The screws are 6.86 mm long and 1.61mm in diameter.
    • Using a Torx T-5 screwdriver remove the screws at the top of the phone.
  9. Use plastic pry tools to free the circuit board from the case There are two hooks (one on each side) holding the circuit board into the case. Then grip the circuit board and lift to remove the circuit board from the case
    • Use plastic pry tools to free the circuit board from the case
    • There are two hooks (one on each side) holding the circuit board into the case.
    • Then grip the circuit board and lift to remove the circuit board from the case
  10. Unhook the antenna by releasing the two hooks, one on each side of the phone. Detach the antenna from the back of the circuit board This small black rubber cover may detach.
    • Unhook the antenna by releasing the two hooks, one on each side of the phone.
    • Detach the antenna from the back of the circuit board
    • This small black rubber cover may detach.
Abschluss
Kyle Olbrich
27 Reputation
4 Anleitungen geschrieben
Clemson, Team 2-2, Benson Spring 2012 Mitglied von Clemson, Team 2-2, Benson Spring 2012
CLEM-BENSON-S12S2G2
3 Mitglieder
15 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 933
