Was du brauchst
Turn the phone so its back is facing you.
Press the release button on the back cover, while simultaneously pulling the cover down.
Remove the back cover.
Orient the phone so its back is facing you.
Using a Torx T-4 screwdriver, carefully remove the 4 screws located at the corners of the phone.
Lodge a spudger in between the front panel and the main frame of the phone.
Using a good amount of torque, pry the front panel from the phone.
Eine weitere Person hat diese Anleitung absolviert.
