Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Einleitung
Use this guide to replace the LCD in your Motorola C350.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use your finger to press the button and free the device rear case. You may have to force it a bit more to free its bottom if you open it for the first time.
    • Use your finger to press the button and free the device rear case.
    • You may have to force it a bit more to free its bottom if you open it for the first time.
  2. slide the black button to free the battery so you can grab it with your other hand.
    • slide the black button to free the battery so you can grab it with your other hand.
  3. You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components. You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
    • You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
  4. Remove the 4 T6 Torx screws Remove the 4 T6 Torx screws
    • Remove the 4 T6 Torx screws
  5. Use a metal spudger to pell off the four metal clips and separate the motherboard and keyboard from the main plastic part. Use a metal spudger to pell off the four metal clips and separate the motherboard and keyboard from the main plastic part.
    • Use a metal spudger to pell off the four metal clips and separate the motherboard and keyboard from the main plastic part.
  6. The last thing you need to doto access the Logic Board is to separate the Keyboard/Screen block just taking apart with your fingers.
    • The last thing you need to doto access the Logic Board is to separate the Keyboard/Screen block just taking apart with your fingers.
  7. Remove the two small metal clips keeping the cables safe.
    • Remove the two small metal clips keeping the cables safe.
  8. Use a plastic spudger to pell off the two cables on the back side of the screen.
    • Use a plastic spudger to pell off the two cables on the back side of the screen.
    • There are two very small connectors. Take care of them and replace them if they incidentally fall.
  9. Use a plastic spudger to release the disconnected screen.
    • Use a plastic spudger to release the disconnected screen.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Vincent Monteil
6.384 Reputation
19 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 2
Letzten 30 Tage: 2
Insgesamt: 480
