Einleitung
Use this guide to replace the earpiece speaker in your Motorola C350.
Was du brauchst
Use your finger to press the button and free the device rear case.
slide the black button to free the battery so you can grab it with your other hand.
You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
Eine weitere Person hat diese Anleitung absolviert.
