Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Einleitung
Use this guide to replace the front case on your Motorola C350.
  1. Use your finger to press the button and free the device rear case. You may have to force it a bit more to free its bottom if you open it for the first time.
    • Use your finger to press the button and free the device rear case.
    • You may have to force it a bit more to free its bottom if you open it for the first time.
  2. slide the black button to free the battery so you can grab it with your other hand.
    • slide the black button to free the battery so you can grab it with your other hand.
  3. You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components. You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
    • You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Vincent Monteil
6.384 Reputation
19 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 225
