Einleitung
Use this guide to replace the pull-out antenna through the back of the device.
Was du brauchst
Remove the battery by sliding it down the rails to which it is connected.
Insert the Phillips 00 screwdriver into the holes that connect the key pad guard to the rear casing in the plastic rod.
Use the screwdriver to push the rods towards each other until they click out of their locked positions.
Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
Push the clips outward while simultaneously lifting the rear casing and keyguard away from the front casing.
Locate and unplug the black component of the current antenna from the motherboard.
Unscrew the blue component in order to free the antenna.
Slide the antenna out of the green tubing.
Slide the green tubing out of its hole.
Screw the blue piece of the antenna into the threaded hole on the motherboard until it is tight.
Align the protruding wire on the black component with the corresponding hole on the motherboard.
Push the wire into the hole.
Reverse the instructions from Step 2 to re-install the keypad guard and rear casing onto the device.
