Einleitung
Motherboard installation requires a teardown of the device.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove the battery by sliding it down the rails to which it is connected.
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Find a flat head or Phillips head screwdriver.
    • Find a flat head or Phillips head screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
    • Use the screwdriver to push the rods towards each other until they click out of their locked position.
    • Note: This may require a large amount of force.
  3. Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Simultaneously push the clips outward while lifting the rear casing and keyguard away from the front casing.
    • Remove the key guard from the rear casing by taking it out of its position.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Locate and unplug the black component of the antenna from the motherboard.
    • Locate and unplug the black component of the antenna from the motherboard.
    • Under the black component should be a blue component. Unscrew this component in order to free the antenna.
  6. Slide the antenna out of the green tubing and slide the green tubing out of it's corresponding hole on the motherboard.
    • Slide the antenna out of the green tubing and slide the green tubing out of it's corresponding hole on the motherboard.
  7. Lift the motherboard out of its location in the front casing.
    • Lift the motherboard out of its location in the front casing.
    • Do this slowly and gently so that none of the motherboard's components are damaged.
  8. With your new motherboard, hold the LCD side of the motherboard face down. Align the four clips on the front casing with the four notches on the motherboard.
    • With your new motherboard, hold the LCD side of the motherboard face down. Align the four clips on the front casing with the four notches on the motherboard.
    • While doing so, insert the LCD into the compartment in the front casing.
  9. Press firmly on the motherboard until it is snug inside the casing.
    • Press firmly on the motherboard until it is snug inside the casing.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Andrew Lam
28 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 9-46, Regan Spring 2012 Mitglied von Cal Poly, Team 9-46, Regan Spring 2012
CPSU-REGAN-S12S9G46
5 Mitglieder
8 Anleitungen geschrieben
Nice, thanks.
Daniel - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 2,416
