Zum Hauptinhalt wechseln
Motorola California Mobile Phone Rear Casing Replacement
Was du brauchst
  1. Motorola California Mobile Phone Rear Casing Replacement, Rear Casing: Schritt 1, Bild 1 von 1
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Motorola California Mobile Phone Rear Casing Replacement: Schritt 2, Bild 1 von 1
    • Find a flat head or Phillips head screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
    • Use the screwdriver to push the rods towards each other until they click out of their locked position.
    • Note: This may require a large amount of force.
  3. Motorola California Mobile Phone Rear Casing Replacement: Schritt 3, Bild 1 von 1
    • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Simultaneously push the clips outward while lifting the old rear casing away from the rest of the device.
  4. Motorola California Mobile Phone Rear Casing Replacement: Schritt 4, Bild 1 von 1
    • Locate the four holes on the new rear casing.
    • Align the holes in the new rear casing with the clips attached the to front casing.
    • Simultaneously insert all four clips.
    • Push down firmly until you hear the clips click into place.
  5. Motorola California Mobile Phone Rear Casing Replacement: Schritt 5, Bild 1 von 1
    • Find a thin and sturdy screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the new key pad guard to the rear casing.
    • Use the screwdriver to push the rods away from each other until they click into their locked position.
Abschluss
Andrew Lam
35 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 9-46, Regan Spring 2012 Mitglied von Cal Poly, Team 9-46, Regan Spring 2012
CPSU-REGAN-S12S9G46
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 977
