Einleitung
The back cover may be made of Kevlar but the camera glass isn't, if it ends up breaking use this to help you replace it with a new one.
Was du brauchst
Remove the SIM card.
Remove the microSD card.
Insert the plastic opening tool between the back cover and the front piece of the case, freeing the plastic clips between the phone.
Do this along the back right side of the phone cover until you reach the top.
Use the plastic opening tool to carefully work your way around the top of the phone, freeing the plastic clips.
Continue using the tool and pry down the remaining side and the bottom of the phone.
With all the plastic clips released, pull away the back cover from the phone to remove it.
Looking at the top rectangular hump where the camera is located, use the plastic opening tool to remove the camera cover.
Using the plastic opening tool, apply pressure into any surrounding crease of the camera cover to remove it.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
