Zum Hauptinhalt wechseln
Motorola Defy LCD Replacement
Was du brauchst
  1. Motorola Defy LCD Replacement, Rear Case: Schritt 1, Bild 1 von 1
    • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
  2. Motorola Defy LCD Replacement: Schritt 2, Bild 1 von 2 Motorola Defy LCD Replacement: Schritt 2, Bild 2 von 2
    • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
  3. Motorola Defy LCD Replacement, Battery: Schritt 3, Bild 1 von 1
    • Use a plastic opening tool to pry the battery out of the phone.
  4. Motorola Defy LCD Replacement, Midframe: Schritt 4, Bild 1 von 1
    • Unscrew the two silver screws located at the top of the back of the phone.
  5. Motorola Defy LCD Replacement: Schritt 5, Bild 1 von 1
    • Use a plastic opening tool to gently pry the midframe from the rest of the phone.
  6. Motorola Defy LCD Replacement, Motherboard: Schritt 6, Bild 1 von 2 Motorola Defy LCD Replacement, Motherboard: Schritt 6, Bild 2 von 2
    • Use metal spudger to pry off the middle yellow flap carefully.
  7. Motorola Defy LCD Replacement: Schritt 7, Bild 1 von 3 Motorola Defy LCD Replacement: Schritt 7, Bild 2 von 3 Motorola Defy LCD Replacement: Schritt 7, Bild 3 von 3
    • Use tweezers again to pry off the second yellow flap carefully.
  8. Motorola Defy LCD Replacement: Schritt 8, Bild 1 von 1
    • The motherboard is the whole green board. Pry it off carefully with tweezers from the sides and place it aside.
  9. Motorola Defy LCD Replacement, Removing the LCD: Schritt 9, Bild 1 von 2 Motorola Defy LCD Replacement, Removing the LCD: Schritt 9, Bild 2 von 2
    • Stick the metal spudger in between the LCD screen and the case of the phone.
    • Remove the LCD screen and replace with a new one.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 14-2, Leahy Fall 2014 Mitglied von USF Tampa, Team 14-2, Leahy Fall 2014
USFT-LEAHY-F14S14G2
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 6
Insgesamt: 1,055
