Zum Hauptinhalt wechseln
Motorola Defy Midframe Replacement
Was du brauchst
  1. Motorola Defy Midframe Replacement, Rear Case: Schritt 1, Bild 1 von 1
    • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
  2. Motorola Defy Midframe Replacement: Schritt 2, Bild 1 von 2 Motorola Defy Midframe Replacement: Schritt 2, Bild 2 von 2
    • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
  3. Motorola Defy Midframe Replacement, Battery: Schritt 3, Bild 1 von 1
    • Use a plastic opening tool to pry the battery out of the phone.
  4. Motorola Defy Midframe Replacement, Midframe: Schritt 4, Bild 1 von 1
    • Unscrew the two silver screws located at the top of the back of the phone.
  5. Motorola Defy Midframe Replacement: Schritt 5, Bild 1 von 1
    • Use a plastic opening tool to gently pry the midframe from the rest of the phone.
Abschluss
Geoff Wacker
89.934 Reputation
89 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 239
