Einleitung
This guide will go through the steps of replacing the motherboard for the Motorola MB525 starting from the tear down of the phone to replacement of the motherboard itself.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
Unscrew the two silver screws located at the top of the back of the phone.
Use a plastic opening tool to gently pry the midframe from the rest of the phone.
The motherboard is the whole green board. Pry it off carefully with tweezers from the sides and place it aside.
