Zum Hauptinhalt wechseln
Motorola Defy Rear Facing Camera Replacement
Was du brauchst
  1. Motorola Defy Rear Facing Camera Replacement, Rear Case: Schritt 1, Bild 1 von 1
    • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
  2. Motorola Defy Rear Facing Camera Replacement: Schritt 2, Bild 1 von 2 Motorola Defy Rear Facing Camera Replacement: Schritt 2, Bild 2 von 2
    • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
  3. Motorola Defy Rear Facing Camera Replacement, Battery: Schritt 3, Bild 1 von 1
    • Use a plastic opening tool to pry the battery out of the phone.
  4. Motorola Defy Rear Facing Camera Replacement, Midframe: Schritt 4, Bild 1 von 1
    • Unscrew the two silver screws located at the top of the back of the phone.
  5. Motorola Defy Rear Facing Camera Replacement: Schritt 5, Bild 1 von 1
    • Use a plastic opening tool to gently pry the midframe from the rest of the phone.
  6. Motorola Defy Rear Facing Camera Replacement, Rear Facing Camera: Schritt 6, Bild 1 von 2 Motorola Defy Rear Facing Camera Replacement, Rear Facing Camera: Schritt 6, Bild 2 von 2
    • Start to pry around the bottom of the camera module with the metal spudger and replace with the new camera module.
    • Be careful of the pins that are connected to the camera module on the bottom.
Abschluss
Morgan Roark
325 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 14-2, Leahy Fall 2014 Mitglied von USF Tampa, Team 14-2, Leahy Fall 2014
USFT-LEAHY-F14S14G2
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 341
