Zum Hauptinhalt wechseln
Motorola Defy XT Screen Replacement
Was du brauchst
  1. Motorola Defy XT Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
  2. Motorola Defy XT Screen Replacement: Schritt 2, Bild 1 von 1
    • Once wedged in the opening, slide the opening tool sideways around the sides of the phone.
    • Remove the back cover and set it aside.
  3. Motorola Defy XT Screen Replacement: Schritt 3, Bild 1 von 1
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
  4. Motorola Defy XT Screen Replacement, SD Card: Schritt 4, Bild 1 von 1
    • Open the plastic cover with your finger, exposing the SD card.
    • Use the opening tool to grab the edge of the SD card and pull it straight out.
  5. Motorola Defy XT Screen Replacement, Screen: Schritt 5, Bild 1 von 2 Motorola Defy XT Screen Replacement, Screen: Schritt 5, Bild 2 von 2
    • Use the Torx T4 screwdriver to remove the six 3 mm screws from the back case.
  6. Motorola Defy XT Screen Replacement: Schritt 6, Bild 1 von 1
    • Use the plastic opening tool to pop the volume buttons off from the side of the phone.
  7. Motorola Defy XT Screen Replacement: Schritt 7, Bild 1 von 1
    • Wedge the plastic opening tool between the plastic layer and the shiny front cover.
  8. Motorola Defy XT Screen Replacement: Schritt 8, Bild 1 von 1
    • Slide the plastic opening tool along the edge, wedging the the two pieces apart.
    • Potential for device damage: Do not completely separate the two pieces; there are still internal components that need to be disconnected.
  9. Motorola Defy XT Screen Replacement: Schritt 9, Bild 1 von 2 Motorola Defy XT Screen Replacement: Schritt 9, Bild 2 von 2
    • Slide the screen out and disconnect the ribbon cable connecting the display to the motherboard by pulling straight outward.
    • Potential for device damage: Be careful when sliding out the screen because the front case and the motherboard are still connected by two other ribbon cables.
  10. Motorola Defy XT Screen Replacement: Schritt 10, Bild 1 von 2 Motorola Defy XT Screen Replacement: Schritt 10, Bild 2 von 2
    • Set the old screen aside and replace it with your new screen.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 2-22, Maness Spring 2013 Mitglied von Cal Poly, Team 2-22, Maness Spring 2013
CPSU-MANESS-S13S2G22
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 3,130
