Zum Hauptinhalt wechseln
Motorola Droid 4 MicroSD/SIM Card Reader Replacement
Was du brauchst
  1. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Removing Rear Panel: Schritt 1, Bild 1 von 3 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Removing Rear Panel: Schritt 1, Bild 2 von 3 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Removing Rear Panel: Schritt 1, Bild 3 von 3
    • Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
    • Slide the cover down to remove.
  2. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Battery: Schritt 2, Bild 1 von 1
    • Remove the sticker on the rear compartment to reveal the battery.
    • Hold the battery with your thumb while removing the sticker or you might end up ripping the battery out of the phone, damaging the flex cable.
  3. Motorola Droid 4 MicroSD/SIM Card Reader Replacement: Schritt 3, Bild 1 von 2 Motorola Droid 4 MicroSD/SIM Card Reader Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    T5 Torx Screwdriver
    $5.49
    Kaufen
    • Use the T5 Torx Screwdriver to remove both 2.5 mm screws from the battery cable.
    • Use the Spudger to unstick the battery.
    • It's difficult to remove the battery without a pry tool like the spudger because of the strong adhesive. If you try removing it with just your fingers, the battery may bend.
  4. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Camera Cover Removal: Schritt 4, Bild 1 von 3 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Camera Cover Removal: Schritt 4, Bild 2 von 3 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Camera Cover Removal: Schritt 4, Bild 3 von 3
    • Using the blue plastic opening tool, pry off the thin plastic camera cover.
    • The plastic cover is fragile, so proceed carefully.
  5. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Remove Screws: Schritt 5, Bild 1 von 2 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Remove Screws: Schritt 5, Bild 2 von 2
    • Remove the four screws, indicated by the red circles, with the screwdriver and T5 Torx bit.
    • The screws are philips 2.5mm. One screw is a different color (silver) from the others (black).
  6. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Remove Bezel: Schritt 6, Bild 1 von 3 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Remove Bezel: Schritt 6, Bild 2 von 3 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Remove Bezel: Schritt 6, Bild 3 von 3
    • Insert the spudger between the rear bezel and the main housing.
    • The bezel is fragile, so proceed carefully.
    • Slide the spudger around all sides of the phone to separate the bezel from the housing.
    • Pry the bezel free.
    • Be careful of the adhesive that holds the bezel to the main housing. Prying too hard may damage your phone.
  7. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Removing screws: Schritt 7, Bild 1 von 2 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Removing screws: Schritt 7, Bild 2 von 2
    • Remove the 12 screws holding the housing in place using a T5 Torx screwdriver.
    • Follow the red circles, indicated in the picture, to locate the screws.
    • The 12 screws are (silver) philips 2.5mm
  8. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Separation of the Housing from the Motherboard: Schritt 8, Bild 1 von 3 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Separation of the Housing from the Motherboard: Schritt 8, Bild 2 von 3 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Separation of the Housing from the Motherboard: Schritt 8, Bild 3 von 3
    • Separate the housing from the motherboard.
    • Be careful while separating the housing. The power and volume buttons are easily separated from the housing and can be damaged.
  9. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, MicroSD/SIM Card Reader: Schritt 9, Bild 1 von 3 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, MicroSD/SIM Card Reader: Schritt 9, Bild 2 von 3 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, MicroSD/SIM Card Reader: Schritt 9, Bild 3 von 3
    • Once the Motherboard Housing is removed the complete Micro SD/SIM card reader is exposed, as indicated by the picture.
    • Remove the two screws that attach the reader to the Motherboard. The locations of the screws are indicated in the picture.
  10. Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Separate the reader from the motherboard: Schritt 10, Bild 1 von 3 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Separate the reader from the motherboard: Schritt 10, Bild 2 von 3 Motorola Droid 4 MicroSD/SIM Card Reader Replacement, Separate the reader from the motherboard: Schritt 10, Bild 3 von 3
    • Using the spudger, pry off the Reader.
    • Be careful while removing the Reader. The connection to the motherboard is composed of small pins.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Javier
530 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 5-1, Mcgee Fall 2014 Mitglied von USF Tampa, Team 5-1, Mcgee Fall 2014
USFT-MCGEE-F14S5G1
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 1,619
