Einleitung
This guide is for the replacement of the motherboard housing. The Motherboard housing encompasses the motherboard and holds it safely. The motherboard is the brain of the phone and should be handled carefully.
You will need to remove several torx head screws. Make sure to use the correct type.
Was du brauchst
Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
Slide the cover down to remove.
In diesem Schritt verwendetes Werkzeug:T5 Torx Screwdriver$5.49
Use the T5 Torx Screwdriver to remove both 2.5 mm screws from the battery cable.
Use the Spudger to unstick the battery.
Using the blue plastic opening tool, pry off the thin plastic camera cover.
Remove the four screws, indicated by the red circles, with the screwdriver and T5 Torx bit.
Insert the spudger between the rear bezel and the main housing.
Slide the spudger around all sides of the phone to separate the bezel from the housing.
Pry the bezel free.
Remove the 12 screws holding the housing in place using a T5 Torx screwdriver.
Follow the red circles, indicated in the picture, to locate the screws.
Separate the housing from the motherboard.
