Zum Hauptinhalt wechseln
Motorola Droid Bionic LCD Replacement
Was du brauchst
  1. Motorola Droid Bionic LCD Replacement, LCD: Schritt 1, Bild 1 von 1
    • Remove the back battery cover.
  2. Motorola Droid Bionic LCD Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery
  3. Motorola Droid Bionic LCD Replacement: Schritt 3, Bild 1 von 2 Motorola Droid Bionic LCD Replacement: Schritt 3, Bild 2 von 2
    • Remove the 11 T4 Torx Screws
    • Next, remove the information sticker.
  4. Motorola Droid Bionic LCD Replacement: Schritt 4, Bild 1 von 2 Motorola Droid Bionic LCD Replacement: Schritt 4, Bild 2 von 2
    • Using a plastic removal tool, work around the edges of the back housing.
    • Lift off the back housing.
  5. Motorola Droid Bionic LCD Replacement: Schritt 5, Bild 1 von 3 Motorola Droid Bionic LCD Replacement: Schritt 5, Bild 2 von 3 Motorola Droid Bionic LCD Replacement: Schritt 5, Bild 3 von 3
    • Remove the two silver T4 screws securing the SIM tray.
    • Carefully lift the SIM tray to disconnect it from the board.
    • Carefully remove the plastic spacer beneath by lifting gently in the center with a plastic removal tool.
    • Then, using a plastic removal tool, disconnect the speaker & front facing camera assembly from the board. The speaker is attached with adhesive, so be careful not to rip the flex cable.
  6. Motorola Droid Bionic LCD Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the 2 digitizer connectors using a plastic removal tool.
    • Then disconnect the LCD connector
  7. Motorola Droid Bionic LCD Replacement: Schritt 7, Bild 1 von 2 Motorola Droid Bionic LCD Replacement: Schritt 7, Bild 2 von 2
    • The board is now free from all connections. Carefully lift from the top and remove the board.
  8. Motorola Droid Bionic LCD Replacement: Schritt 8, Bild 1 von 2 Motorola Droid Bionic LCD Replacement: Schritt 8, Bild 2 von 2
    • Carefully peel the two flex cables from the back housing of the LCD. Be exceptionally careful during this process, as those flex cables can be easily ripped.
    • With the flex cables out of the way, you can now use a plastic opening tool to carefully pry the old LCD loose and out of the display.
    • If you're installing a new LCD, simply add it now and follow these instructions in reverse to complete the installation.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Taylor
244 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,767
