Zum Hauptinhalt wechseln
Motorola Droid MAXX 2 Earpiece Speaker Replacement
Was du brauchst
  1. Motorola Droid MAXX 2 Earpiece Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
  2. Motorola Droid MAXX 2 Earpiece Speaker Replacement: Schritt 2, Bild 1 von 1
    • Pull the sim card tray up out of the phone
  3. Motorola Droid MAXX 2 Earpiece Speaker Replacement: Schritt 3, Bild 1 von 2 Motorola Droid MAXX 2 Earpiece Speaker Replacement: Schritt 3, Bild 2 von 2
    • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
  4. Motorola Droid MAXX 2 Earpiece Speaker Replacement: Schritt 4, Bild 1 von 1
    • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • These may be T3 screws. If you are having trouble unscrewing these, stop and try a T3 bit.
  5. Motorola Droid MAXX 2 Earpiece Speaker Replacement: Schritt 5, Bild 1 von 1
    • Pull the mid-frame off of the phone.
    • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
  6. Motorola Droid MAXX 2 Earpiece Speaker Replacement: Schritt 6, Bild 1 von 3 Motorola Droid MAXX 2 Earpiece Speaker Replacement: Schritt 6, Bild 2 von 3 Motorola Droid MAXX 2 Earpiece Speaker Replacement: Schritt 6, Bild 3 von 3
    • Remove the static tape covering the two connectors.
    • Use a spudger to disconnect the battery cables from the motherboard.
    • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  7. Motorola Droid MAXX 2 Earpiece Speaker Replacement: Schritt 7, Bild 1 von 1
    • Remove the disconnected battery from the phone.
  8. Motorola Droid MAXX 2 Earpiece Speaker Replacement, Earpiece Speaker: Schritt 8, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Grab the speaker with the tweezers and gently pull up on the speaker.
    • The speaker is held in place around the edges with adhesive, so there will be some resistance when you try to remove the speaker from the phone.
Abschluss
Baylor, Team S3-G4, Williams Spring 2018 Mitglied von Baylor, Team S3-G4, Williams Spring 2018
BU-WILLIAMS-S18S3G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 688
