Einleitung
How to replace the rear camera on the Motorola Droid MAXX 2 if the back camera isn't working properly.
Was du brauchst
Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
Remove the static tape covering the two connectors.
Use a spudger to disconnect the battery cables from the motherboard.
If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
Use a spudger to lift up the black tab on the ZIF connector.
Remove the camera.
