Einleitung
The camera or flash may stop functioning or require eventual replacement. Here is a guide that offers that.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Pull out the volume keys using the plastic opening tool. Pull out the volume keys using the plastic opening tool.
    • Pull out the volume keys using the plastic opening tool.
  2. Use the plastic opening tool to gently pry off the back case. Make sure to go around the entire perimeter of the case. Use the plastic opening tool to gently pry off the back case. Make sure to go around the entire perimeter of the case.
    • Use the plastic opening tool to gently pry off the back case. Make sure to go around the entire perimeter of the case.
  3. Use the T5 screw head to unscrew the 9 silver screws from the housing frame.
    • Use the T5 screw head to unscrew the 9 silver screws from the housing frame.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Carefully separate the housing frame from the motherboard.
    • Carefully separate the housing frame from the motherboard.
  6. Carefully use the tweezers to separate the motherboard from the screen. Carefully use the tweezers to separate the motherboard from the screen.
    • Carefully use the tweezers to separate the motherboard from the screen.
  7. Carefully use the tweezers to remove the flash motherboard. Carefully use the tweezers to remove the flash motherboard.
    • Carefully use the tweezers to remove the flash motherboard.
  8. Using the tweezers, remove the camera from the motherboard. Using the tweezers, remove the camera from the motherboard.
    • Using the tweezers, remove the camera from the motherboard.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Alec Fales
313 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 9-2, Leahy Fall 2014 Mitglied von USF Tampa, Team 9-2, Leahy Fall 2014
USFT-LEAHY-F14S9G2
3 Mitglieder
5 Anleitungen geschrieben
What’s the OEM number of the flash motherboard ‘coz my flash died and I want to buy a new one.
Any help is much appreciated!
creativeinventiondesign - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 1,363
