Zum Hauptinhalt wechseln
Motorola Droid Pro SD Card/SIM Card PCB Board Replacement
Was du brauchst
  1. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the back cover using the thumb tab located on the bottom of the phone.
  2. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: Schritt 2, Bild 1 von 2 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery using the thumb tab.
  3. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, SD Card/SIM Card PCB Board: Schritt 3, Bild 1 von 2 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, SD Card/SIM Card PCB Board: Schritt 3, Bild 2 von 2
    • Using a T4 Torx driver, remove the eight 4 mm back panel screws.
  4. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: Schritt 4, Bild 1 von 3 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: Schritt 4, Bild 2 von 3 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: Schritt 4, Bild 3 von 3
    • Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use extra force to unlock them.
    • Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
  5. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: Schritt 5, Bild 1 von 2 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: Schritt 5, Bild 2 von 2
    • Gently lift the SD & SIM card board (PCB) as shown.
    • There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Kyle Shays
836 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 1-6, Miles Fall 2015 Mitglied von UMass Dartmouth, Team 1-6, Miles Fall 2015
UMASSD-MILES-F15S1G6
3 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Does the replacement board have to be from the same phone or does any sim board work from any phone as long as it's 3g
lisa marie - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 311
