Zum Hauptinhalt wechseln
Motorola Droid Pro Screen Replacement
Was du brauchst
  1. Motorola Droid Pro Screen Replacement, SD Card/SIM Card PCB Board: Schritt 1, Bild 1 von 2 Motorola Droid Pro Screen Replacement, SD Card/SIM Card PCB Board: Schritt 1, Bild 2 von 2
    • Remove the back cover and battery by using the thumb tabs.
  2. Motorola Droid Pro Screen Replacement: Schritt 2, Bild 1 von 1
    • Unscrew the 8 back panel screws using the T4 Torx screwdriver.
  3. Motorola Droid Pro Screen Replacement: Schritt 3, Bild 1 von 1
    • Use a spudger to open the phone along the sides between the back panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use a little force to unlock them.
    • Go around on all sides then pull the back panel off.
  4. Motorola Droid Pro Screen Replacement: Schritt 4, Bild 1 von 2 Motorola Droid Pro Screen Replacement: Schritt 4, Bild 2 von 2
    • Gently lift the SD & SIM card board (PCB) as shown in the following pictures.
    • This will expose the ribbon cable attached to the board and another ribbon cable for the mother board. Remove them both using the spudger.
    • Once the small one is removed the small board can be pulled off.
  5. Motorola Droid Pro Screen Replacement, Screen: Schritt 5, Bild 1 von 1
    • Unscrew the 6 screws using the T5 Torx screwdriver.
  6. Motorola Droid Pro Screen Replacement: Schritt 6, Bild 1 von 1
    • Unlock the ribbon cable and then you can pull the screen out.
    • When replacing screen make sure you lock the ribbon cable back in place.
Abschluss
Peter Cakounes
19 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 5-8, Vijaybhaskar Fall 2014 Mitglied von UMass Dartmouth, Team 5-8, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G8
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 270
