Einleitung
What's the point of a phone if it can't take 8 megapixel pictures, right? Replace the rear-facing HD camera in your Droid RAZR to help keep your Mobile Uploads album on Facebook up to-date.
Was du brauchst
Insert a plastic opening tool between the back cover and rear case at the lower left edge of the back cover.
Pry the back cover up with the plastic opening tool to free the plastic clips.
Continue prying along the left edge of the back cover towards the top of the phone.
Work the plastic opening tool across the top of the back case to free the plastic clips.
Continue prying down the right side of the back cover to free the remaining clips.
Use the tip of a spudger to lift up the red silicone cover over the battery terminal screws and remove it.
Remove the two 3.3 mm T5 Torx battery terminal screws.
Grab the blue battery removal tab and lift the battery out to remove it.
Use a heat gun or hair dryer to soften the adhesive underneath the camera cover.
Gently pry up the bottom edge of the camera cover with a plastic opening tool.
Carefully slide the plastic opening tool across the bottom edge to free it from the adhesive.
Continue to use the heat gun as needed to soften the adhesive as you remove the camera cover.
Insert the plastic opening tool underneath the top edge of the camera cover.
Gently pry the camera cover up as you slide the plastic opening tool across the top edge to free it from the adhesive.
Remove the camera cover.
Remove the six screws securing the rear case to the rest of the phone:
three 6.7 mm silver T3 Torx screws at the top,
four 4.0 mm gold T3 Torx screws in the middle,
and three 4.5 mm black T5 Torx screws at the bottom.
Insert a plastic opening tool between the rear case and the motherboard assembly.
Work your way down the side of the phone and gently pry the rear case up.
Separate the rear case from the motherboard assembly.
Remove the three 2.5 mm T3 Torx screws securing the metal chassis to the motherboard.
Remove the metal chassis from the motherboard assembly.
Use the flat end of a spudger to remove the two red silicone microphone covers at the top and bottom of the motherboard.
Use the tip of a spudger to gently bend the clips out of shape and remove the shield.
Use the flat end of a spudger to pry the three display cable connectors off their sockets on the motherboard.
Use a heat gun or hair dryer to soften the adhesive strip around the perimeter of the motherboard.
Pry the edges of the motherboard up from the display assembly with a plastic opening tool.
Remove the motherboard assembly.
Lift up the anti-static tape covering the camera and earpiece ZIF connectors with the tip of a spudger.
Peel back the tape and remove it.
Use a plastic opening tool or your fingernail to lift up the tab on the rear-facing camera ribbon cable ZIF connector.
Push the rear-facing camera through its hole in the grey antenna and remove it.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
