Einleitung
This guide will show you how to apply new adhesive to the rear cover of your Motorola Droid Turbo 2 to seal it up after a repair.
Was du brauchst
Prepare the phone frame surface by removing all traces of adhesive.
Use tweezers to pull adhesive chunks off. Use the opening tool to scrape residue off. You can use high concentration (over 90%) isopropyl alcohol to help dissolve residue.
If you are re-using the rear cover, prepare the inner surface by removing all traces of adhesive from it.
Use your finger and firmly press the metal rear camera plate from the outer side of the rear cover until you dislodge it from its recess.
Remove the rear camera plate.
Clean the perimeter of the rear camera plate and remove any adhesive residue.
Set the pre-cut adhesive strip next to the rear cover so that it is properly oriented—the pull tabs should point to the bottom left corner of the cover.
Lay the pre-cut adhesive strip over the rear cover, aligning it to the long edges.
Tape one long edge of the pre-cut adhesive strip to the rear cover, locking the alignment in place while allowing the strip to still swing.
Align the adhesive strip to a long edge of the rear cover.
Beginning from the alignment edge, use your fingers to press the adhesive strip onto the rear cover.
Pull and remove the blue liner tab located in the rear cover's rear camera hole.
Align the rear camera plate with the rear cover's camera hole and drop it in place.
Press the rear camera plate in place. You may need to squeeze from both sides to ensure that the adhesive bonds properly.
Continue with phone re-assembly until you are ready to seal up the phone.
Peel and remove the blue liner from the rear cover, exposing the adhesive to stick onto the phone frame.
Align and press the rear cover onto the phone frame.
Repair didn’t go as planned? Check out our Motorola Droid Turbo 2 Answers community for troubleshooting help.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
