Einleitung
Follow these steps to remove your Droid's broken rear-facing camera.
Was du brauchst
Insert a SIM eject tool, SIM eject bit, or a straightened paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Remove the SIM card tray assembly from the phone.
Slide the opening pick along the top edge of the phone to break up the adhesive.
Use the pick to release the deeper areas but avoid slicing through the camera bezel area.
Repeat the iOpener heating and slicing procedures for the remaining three sides.
Once you have cut through the adhesive, slowly peel the back cover away from the frame.
Remove the back cover.
Insert an opening pick under the flash connector rubber cover and pry forward to remove it.
Use the point of a spudger to pry up and remove the coil connector rubber cover.
To reinstall the cover, align the cover and use your finger to push it forward into place.
Use the point of a spudger to pry up and disconnect the wireless charging coil connector.
Remove the following T3 screws securing the midframe:
Thirteen 3.1 mm black screws
Four 4.3 mm silver screws
Insert an opening pick along the frame seam and twist slightly to release the midframe from the phone.
Using your fingers, carefully remove the black tape from the battery.
Using a T4 bit on your screw driver, remove the two 4.0mm screws from the metal bracket.
Remove the metal bracket.
Use the angled tweezers to lift up the small orange plastic piece near the bottom right corner of the battery.
Use the pointed tweezers to remove the transparent gold tape on top of the ZIF connector.
Slightly unlatch the ZIF connector with the spudger. It will pop up, but it will not completely detach.
Using the blunt tweezers, remove the transparent gold tape from the small gold ribbon near the bottom right of the battery.
Use the spudger to then unlatch the ribbon cable connector.
Using a plastic opening tool, unclip the small black ribbon near the upper right corner of the battery.
Gently lift up the motherboard and use the blunt tweezers to detach the black antenna cable connector near the top of the battery.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
