Zum Hauptinhalt wechseln
Motorola Droid Turbo Dual LED Flash Board Replacement
Was du brauchst
  1. Motorola Droid Turbo Dual LED Flash Board Replacement, Rear Case: Schritt 1, Bild 1 von 1
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
  2. Motorola Droid Turbo Dual LED Flash Board Replacement: Schritt 2, Bild 1 von 2 Motorola Droid Turbo Dual LED Flash Board Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
  3. Motorola Droid Turbo Dual LED Flash Board Replacement, Dual LED Flash Board: Schritt 3, Bild 1 von 2 Motorola Droid Turbo Dual LED Flash Board Replacement, Dual LED Flash Board: Schritt 3, Bild 2 von 2
    • Use a Jimmy to separate the dual LED flash board from the rear case.
    • The board is secured with some light adhesive, so some force may be required.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Geoff Wacker
92.023 Reputation
89 Anleitungen geschrieben
1 Kommentar zur Anleitung
Gostaria se possível alguem tenha o manual de serviço do Moto maxx XT 1225 ou 1254. Porf favor , ddani8260@gmail.com
Daniel Gomes - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 1,100
