Einleitung
Use this guide to replace the vibrator in your Motorola Droid Turbo.
Was du brauchst
Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
Use a plastic opening tool to pry the rear case off of the rest of the device.
Remove the rear case.
Use the pointed end of a spudger to gently pry the vibrator up and away from the midframe.
Fast fertig!
Abschluss
