Zum Hauptinhalt wechseln
Motorola Droid Turbo Vibrator Replacement
Was du brauchst
  1. Motorola Droid Turbo Vibrator Replacement, Rear Case: Schritt 1, Bild 1 von 1
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
  2. Motorola Droid Turbo Vibrator Replacement: Schritt 2, Bild 1 von 2 Motorola Droid Turbo Vibrator Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
  3. Motorola Droid Turbo Vibrator Replacement, Midframe: Schritt 3, Bild 1 von 1
    • Remove the midframe bezel.
  4. Motorola Droid Turbo Vibrator Replacement: Schritt 4, Bild 1 von 1
    • Remove the four Torx T5 screws securing the midframe plate.
  5. Motorola Droid Turbo Vibrator Replacement: Schritt 5, Bild 1 von 1
    • Remove the midframe.
  6. Motorola Droid Turbo Vibrator Replacement, Vibrator: Schritt 6, Bild 1 von 2 Motorola Droid Turbo Vibrator Replacement, Vibrator: Schritt 6, Bild 2 von 2
    • Use the pointed end of a spudger to gently pry the vibrator up and away from the midframe.
Abschluss
Geoff Wacker
87.908 Reputation
89 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 1,176
