Einleitung
If one needs access to the inner components of the Droid X or they are needing to replace the rear plastic of the device, this guide will walk a reader through the necessary steps.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Locate the power button at the top of the phone.  Depress power button for 2 seconds until a menu appears. Locate the power button at the top of the phone.  Depress power button for 2 seconds until a menu appears.
    • Locate the power button at the top of the phone. Depress power button for 2 seconds until a menu appears.
  2. Once the menu appears, select the "power off" option.  Wait until the phone is completely off. Once the menu appears, select the "power off" option.  Wait until the phone is completely off.
    • Once the menu appears, select the "power off" option. Wait until the phone is completely off.
  3. Place thumb on the back cover, and push down towards the bottom of the device.  Once the cover releases, pull it away from the phone and set it aside. Place thumb on the back cover, and push down towards the bottom of the device.  Once the cover releases, pull it away from the phone and set it aside.
    • Place thumb on the back cover, and push down towards the bottom of the device. Once the cover releases, pull it away from the phone and set it aside.
  4. Find the yellow pull tab located in the upper left corner.  Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case. Find the yellow pull tab located in the upper left corner.  Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case.
    • Find the yellow pull tab located in the upper left corner. Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case.
  5. The battery has been successfully removed.
    • The battery has been successfully removed.
  6. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  7. Remove the micro SD card from its connector.
    • Remove the micro SD card from its connector.
  8. Locate the seam between the back case and the end cover on the top edge of the phone. Use the plastic opening tool to detach the two clips by wedging the tool into the right side of the seam and moving right to left.  Once the cover comes off set it aside Use the plastic opening tool to detach the two clips by wedging the tool into the right side of the seam and moving right to left.  Once the cover comes off set it aside
    • Locate the seam between the back case and the end cover on the top edge of the phone.
    • Use the plastic opening tool to detach the two clips by wedging the tool into the right side of the seam and moving right to left. Once the cover comes off set it aside
  9. Repeat step 2 on the bottom cover. Repeat step 2 on the bottom cover. Repeat step 2 on the bottom cover.
    • Repeat step 2 on the bottom cover.
  10. Use a T5 Torx screwdriver to remove the screws in each corner of the phone. The screws are very small so make sure not to lose them. The screws are very small so make sure not to lose them.
    • Use a T5 Torx screwdriver to remove the screws in each corner of the phone.
    • The screws are very small so make sure not to lose them.
  11. Flip the phone over and locate the screw on the middle of the left side. Unscrew it using the T5 Torx screwdriver and set it aside. Flip the phone over and locate the screw on the middle of the left side. Unscrew it using the T5 Torx screwdriver and set it aside.
    • Flip the phone over and locate the screw on the middle of the left side. Unscrew it using the T5 Torx screwdriver and set it aside.
  12. Identify the screw located in the bottom right corner of the battery case.  Remove the screw with a T5 (or in some cases T6) torx screwdriver and set it aside. Identify the screw located in the bottom right corner of the battery case.  Remove the screw with a T5 (or in some cases T6) torx screwdriver and set it aside.
    • Identify the screw located in the bottom right corner of the battery case. Remove the screw with a T5 (or in some cases T6) torx screwdriver and set it aside.
  13. Locate the seam along the right edge of the phone.  Use the prying tool to disconnect the two clips along the edge. Locate the seam along the right edge of the phone.  Use the prying tool to disconnect the two clips along the edge.
    • Locate the seam along the right edge of the phone. Use the prying tool to disconnect the two clips along the edge.
  14. Locate the two clips on the inside of the case and use the spudger tool to detach them from the case.  To detach each clip, use the sharp end to press the small, black plastic in the center of the clip. Locate the two clips on the inside of the case and use the spudger tool to detach them from the case.  To detach each clip, use the sharp end to press the small, black plastic in the center of the clip. Locate the two clips on the inside of the case and use the spudger tool to detach them from the case.  To detach each clip, use the sharp end to press the small, black plastic in the center of the clip.
    • Locate the two clips on the inside of the case and use the spudger tool to detach them from the case. To detach each clip, use the sharp end to press the small, black plastic in the center of the clip.
  15. After the clips are detached, remove the back case and set it aside. After the clips are detached, remove the back case and set it aside.
    • After the clips are detached, remove the back case and set it aside.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Sam Johnston
486 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 18-40, Regan Fall 2012 Mitglied von Cal Poly, Team 18-40, Regan Fall 2012
CPSU-REGAN-F12S18G40
3 Mitglieder
5 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 737
