Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Objective: remove the rear case from the Motorola Droid X phone.
    • Objective: remove the rear case from the Motorola Droid X phone.
    • This is what the Motorola Droid X looks like before disassembly. In the front, there is a large LCD touch screen.
  2. INSTRUCTION: Turn the phone over so that the back faces up.
    • INSTRUCTION: Turn the phone over so that the back faces up.
  3. Objective: remove the battery casing plate.
    • Objective: remove the battery casing plate.
    • The case plate has a push and slide mechanism.
  4. INSTRUCTION 1: Push on the upper side of the casing located under the camera lens.
    • INSTRUCTION 1: Push on the upper side of the casing located under the camera lens.
    • INSTRUCTION 2: Slide down the battery case plate.
  5. INSTRUCTION: Insert your finger tips into the edges of the opening and pull the casing off.
    • INSTRUCTION: Insert your finger tips into the edges of the opening and pull the casing off.
  6. Objective: remove the battery from the battery compartment.
    • Objective: remove the battery from the battery compartment.
  7. INSTRUCTION: Grab the red tab that says "Battery Release" and slowly lift it up. This will remove the battery.
    • INSTRUCTION: Grab the red tab that says "Battery Release" and slowly lift it up. This will remove the battery.
  8. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  9. Objective:  remove two small black screws from the back of the phone.
    • Objective: remove two small black screws from the back of the phone.
    • These two (2) screws help hold the phone together. They need to be removed by a Phillips Hex 2mm screwdriver,
  10. INSTRUCTION: Remove two black screws from the back of the phone.
    • INSTRUCTION: Remove two black screws from the back of the phone.
  11. Objective: remove the two plastic pieces in front of the phone - they cover the remaining screws.
    • Objective: remove the two plastic pieces in front of the phone - they cover the remaining screws.
    • The two plastic pieces are clipped onto the phone as covers. They are located at the top and the bottom of the phone.
  12. INSTRUCTION: Flip the phone over to the front side.
    • INSTRUCTION: Flip the phone over to the front side.
  13. INSTRUCTION: Use the iFixit tool as a crowbar to pry the top plastic cover piece off of the phone.  It will pop off.
    • INSTRUCTION: Use the iFixit tool as a crowbar to pry the top plastic cover piece off of the phone. It will pop off.
  14. INSTRUCTION: Use the iFixit tool as a crowbar to pry the bottom plastic piece off the phone.
    • INSTRUCTION: Use the iFixit tool as a crowbar to pry the bottom plastic piece off the phone.
  15. Objective: remove four white screws from the corners of the screen.
    • Objective: remove four white screws from the corners of the screen.
    • These four (4) screws help hold the phone together. Use a Phillips Hex 2mm screwdriver
  16. INSTRUCTION: remove the 2 white screws from the upper corners of the screen.
    • INSTRUCTION: remove the 2 white screws from the upper corners of the screen.
  17. INSTRUCTION: remove the 2 white screws from the lower corners of the screen.
    • INSTRUCTION: remove the 2 white screws from the lower corners of the screen.
  18. Objective: remove the rear case from the phone in order to provide access to inside the phone.
    • Objective: remove the rear case from the phone in order to provide access to inside the phone.
    • The phone is now held together by the casing alone. You need to pop the two halves apart.
  19. INSTRUCTION: Use the iFixit tool like a crowbar to pry apart the front and rear halves of the  casing. They will pop apart.
    • INSTRUCTION: Use the iFixit tool like a crowbar to pry apart the front and rear halves of the casing. They will pop apart.
  20. Now you are ready to access the internal circuits of the phone.
    • Now you are ready to access the internal circuits of the phone.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Anna
28 Reputation
1 Anleitung geschrieben
Ohio State, Team 1-1, Voss Fall 2012 Mitglied von Ohio State, Team 1-1, Voss Fall 2012
OSU-VOSS-F12S1G1
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 689
