Zum Hauptinhalt wechseln
Einleitung
This guide is for if your battery is dying and you need to replace it with another. No tools are need for this replacement. It is very straight forward.
  1. Slide the plastic case off of the back of the phone, exposing the battery. Slide the plastic case off of the back of the phone, exposing the battery. Slide the plastic case off of the back of the phone, exposing the battery.
    • Slide the plastic case off of the back of the phone, exposing the battery.
  2. Pull up on the red battery release tab and pull the battery out of the phone. Pull up on the red battery release tab and pull the battery out of the phone. Pull up on the red battery release tab and pull the battery out of the phone.
    • Pull up on the red battery release tab and pull the battery out of the phone.
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Aaron Mak
658 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 4-3, Miles Fall 2014 Mitglied von UMass Dartmouth, Team 4-3, Miles Fall 2014
UMASSD-MILES-F14S4G3
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 4
Insgesamt: 1,068
