Einleitung
This guide shows you how to replace the camera as it may be damaged or malfunctioning. The removal of the camera itself is simple, but getting there can be tricky because of the motherboard. Carefully follow guide. Tools are required for this.
Was du brauchst
Slide the plastic case off of the back of the phone, exposing the battery.
Remove the circled screws using a T-5 torques. These screws will be 4.3 millimeters in length.
Using a prying tool, snap off the front casing on the top and bottom of the phone.
Remove the circled screws using a T-5 torques.. These screws should be 5.8 millimeters in length.
Using a plastic opening tool, snap open the phone. It should separate into a front piece with the hardware and a plastic backing.
Remove these nine screws using a T-3 torques. These screws should be 2.40 mm in length
Using tweezers, carefully disconnect the cable connector by pulling the cable out.
Using a spudger, remove the camera. Lift up the motherboard and slide the spudger under the camera.
Ein Kommentar
how do u get it back on when it dose not come back on
brianna
