Zum Hauptinhalt wechseln
Motorola Entice w766 Motherboard Replacement
Was du brauchst
  1. Motorola Entice w766 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the tab off the back of the device.
  2. Motorola Entice w766 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Use the tab located at the top of the battery to release the battery.
  3. Motorola Entice w766 Motherboard Replacement, Motherboard: Schritt 3, Bild 1 von 3 Motorola Entice w766 Motherboard Replacement, Motherboard: Schritt 3, Bild 2 von 3 Motorola Entice w766 Motherboard Replacement, Motherboard: Schritt 3, Bild 3 von 3
    • The six screws need to be taken out with any conventional screw driver tool.
    • You will have to unscrew the six 5.31 mm Star Head #5 screws with the appropriate six star bit.
    • There should be six screws removed from the casing after completion.
  4. Motorola Entice w766 Motherboard Replacement: Schritt 4, Bild 1 von 3 Motorola Entice w766 Motherboard Replacement: Schritt 4, Bild 2 von 3 Motorola Entice w766 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • First you will need to locate the lip on the left side of the device.
    • Next you will insert the black spudger firmly into side opening to loosen the casing.
    • Using the blue pry tool gently remove the black and silver casing.
    • The motherboard should then be exposed after removal.
  5. Motorola Entice w766 Motherboard Replacement: Schritt 5, Bild 1 von 3 Motorola Entice w766 Motherboard Replacement: Schritt 5, Bild 2 von 3 Motorola Entice w766 Motherboard Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the flex cable with a pair of tweezers.
    • Be gentle with the flex cable as not to break the connecting wire.
    • Now use a spudger or pry tool to place firmly under the motherboard.
    • After creating clearance with the spudging device grab and remove the motherboard with a clamping tool or hand.
    • Look at the motherboard for scorches or loose pieces which could indicate damage.
    • Refer to the troubleshooting page for further advice to replace the motherboard.
Abschluss
Aalan Miranda
210 Reputation
2 Anleitungen geschrieben
IUPUI-Harley-F16S2G4 Mitglied von IUPUI-Harley-F16S2G4
Community
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 215
