Zum Hauptinhalt wechseln
Motorola Lapdock 100 Speakers Replacement
Was du brauchst
  1. Motorola Lapdock 100 Speakers Replacement, Lower Case: Schritt 1, Bild 1 von 2 Motorola Lapdock 100 Speakers Replacement, Lower Case: Schritt 1, Bild 2 von 2
    • To take off the Keyboard there are three tabs at the top of the Keyboard in the locations shown in the picture that you must press and unclip. They are located behind each of the keys that are removed.
    • You do not need to remove any keys to unclip the keyboard. We did this for picture purposes only.
  2. Motorola Lapdock 100 Speakers Replacement: Schritt 2, Bild 1 von 1
    • You can use a small metal spudger to depress each tab to avoid scratching the keyboard.
  3. Motorola Lapdock 100 Speakers Replacement: Schritt 3, Bild 1 von 1
    • Lift up keyboard so that you are able to see the ribbon cable connected to the contact.
  4. Motorola Lapdock 100 Speakers Replacement: Schritt 4, Bild 1 von 2 Motorola Lapdock 100 Speakers Replacement: Schritt 4, Bild 2 von 2
    • Flip up the ZIF connector holding the ribbon cable on the contact as shown in the two pictures and then gently disconnect the ribbon cable.
  5. Motorola Lapdock 100 Speakers Replacement: Schritt 5, Bild 1 von 2 Motorola Lapdock 100 Speakers Replacement: Schritt 5, Bild 2 von 2
    • After we remove the Keyboard, you can clearly see the screws under it. Remove the ten 3mm long phillips head screws.
  6. Motorola Lapdock 100 Speakers Replacement: Schritt 6, Bild 1 von 3 Motorola Lapdock 100 Speakers Replacement: Schritt 6, Bild 2 von 3 Motorola Lapdock 100 Speakers Replacement: Schritt 6, Bild 3 von 3
    • Flip over the Lapdock and remove the four 3.5mm long phillips head screws from the bottom.
  7. Motorola Lapdock 100 Speakers Replacement: Schritt 7, Bild 1 von 2 Motorola Lapdock 100 Speakers Replacement: Schritt 7, Bild 2 von 2
    • Use a plastic prying tool to take off the bottom case. Make sure that all of the clips are unclipped before trying to remove the case.
  8. Motorola Lapdock 100 Speakers Replacement, Speakers: Schritt 8, Bild 1 von 2 Motorola Lapdock 100 Speakers Replacement, Speakers: Schritt 8, Bild 2 von 2
    • Remove the two 2mm long phillips head screws from each speaker.
  9. Motorola Lapdock 100 Speakers Replacement: Schritt 9, Bild 1 von 2 Motorola Lapdock 100 Speakers Replacement: Schritt 9, Bild 2 von 2
    • Insert wisdom here.
  10. Motorola Lapdock 100 Speakers Replacement: Schritt 10, Bild 1 von 1
    • Unplug speakers from master chip.
  11. Motorola Lapdock 100 Speakers Replacement: Schritt 11, Bild 1 von 2 Motorola Lapdock 100 Speakers Replacement: Schritt 11, Bild 2 von 2
    • Unhook each speaker wire from the tabs that are holding them in place.
  12. Motorola Lapdock 100 Speakers Replacement: Schritt 12, Bild 1 von 1
  13. Motorola Lapdock 100 Speakers Replacement: Schritt 13, Bild 1 von 1
    • Gently unplug the speaker connection from the motherboard.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 5
Insgesamt: 146
