Zum Hauptinhalt wechseln
Motorola MBP667CONNECT Battery Replacement
Was du brauchst
  1. Motorola MBP667CONNECT Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • The battery casing is on the back of the monitor housing.
  2. Motorola MBP667CONNECT Battery Replacement: Schritt 2, Bild 1 von 2 Motorola MBP667CONNECT Battery Replacement: Schritt 2, Bild 2 von 2
    • Notice the little crevice at the bottom of the baby monitor. This is how the lid is removed. Simply put pressure with your finger to the crevice and lift.
    • Remove the battery casing lid from the back of the monitor housing.
  3. Motorola MBP667CONNECT Battery Replacement: Schritt 3, Bild 1 von 1
    • There is a plastic part connecting the wires of the battery to the device.
    • Disconnect the battery wiring from the monitor battery connection.
  4. Motorola MBP667CONNECT Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove and discard the old battery and replace it with a new battery.
Abschluss
Kyle Kramer
255 Reputation
2 Anleitungen geschrieben
Ein Kommentar
just bought the battery linked and it has a slightly different, incompatible fitting. If i find one that works I’ll post…
Alex Chassy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 20
Insgesamt: 5,102
