Zum Hauptinhalt wechseln
Motorola MOTO W755 Cell Phone Main Logic Board Replacement
Was du brauchst
  1. Motorola MOTO W755 Cell Phone Main Logic Board Replacement, Battery: Schritt 1, Bild 1 von 2 Motorola MOTO W755 Cell Phone Main Logic Board Replacement, Battery: Schritt 1, Bild 2 von 2
    • Using your finger, press down on the clip holding the back cover on
    • Pull the back cover off.
  2. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: Schritt 2, Bild 1 von 2 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: Schritt 2, Bild 2 von 2
    • Place thumb and index finger in the spaces on either side of the battery.
    • Pull battery out.
  3. Motorola MOTO W755 Cell Phone Main Logic Board Replacement, Main Logic Board: Schritt 3, Bild 1 von 1
    • Using the T5 Torx-screwdriver, remove the four 5.5 mm screws on the back panel.
  4. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: Schritt 4, Bild 1 von 2 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: Schritt 4, Bild 2 von 2
    • Using a plastic opening tool, carefully peel back the rubber strip located at the bottom of the keypad
    • Remove the two T5 Torx-screws underneath the rubber strip using the T5 Torx-screwdriver
  5. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: Schritt 5, Bild 1 von 3 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: Schritt 5, Bild 2 von 3 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: Schritt 5, Bild 3 von 3
    • Using the flat end of the plastic opening tool, insert it in the gap between the charging port and plastic at the bottom left side of the phone.
    • Slide the opening tool around the phone clockwise until you reach the audio port.
    • Twist the opening tool until the plastic pops off from the body of the phone. This make require a small amount of force.
  6. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: Schritt 6, Bild 1 von 1
    • Remove the plastic covering completely from the body of the phone.
  7. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: Schritt 7, Bild 1 von 2 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: Schritt 7, Bild 2 von 2
    • Using the plastic opening tool, carefully unclip the cable ribbon from the main logic board. Be sure not to tear it because the flex is very fragile.
    • Remove the main logic board.
Abschluss
C Miller
56 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 1-3, Regan SU 2012 Mitglied von Cal Poly, Team 1-3, Regan SU 2012
CPSU-REGAN-SU12S1G3
2 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 1,524
