Einleitung
Replace the top panel for your Motorola MOTO phone.
Was du brauchst
Using your finger, press down on the clip holding the back cover on
Pull the back cover off.
Place thumb and index finger in the spaces on either side of the battery.
Pull battery out.
Use the plastic opening tool to pull peel back screen cover.
Gently peel back the screen cover from the speaker slit.
Using the T6 Torx-screwdriver, remove the four 4.3 mm screws from the top panel.
Using the flat end of the plastic opening tool, insert it underneath the plastic cover on the top right corner.
Move the opening tool around the phone counter clockwise.
Pop the plastic cover off by twisting the plastic covering tool.
Using a flat head screwdriver, insert it between the metal logic board casing and the top portion of the phone
Move the plastic opening tool around the phone until part of the casting is popped off.
You will need to pop in the four plastic fasteners individually from the metal casing to remove it
Be careful not to rip the cable ribbons that are attached to the logic board and casing
Use the flat end of the plastic opening tool to unclip the cable ribbon from the logic board
Eine weitere Person hat diese Anleitung absolviert.
