Einleitung
If your Motorola Moto 360 3rd Gen smartwatch is having trouble holding a charge, or is not charging at all, you might need to replace the battery. Before replacing the battery, make sure that there is no dust around the charging pins or ports. Furthermore, make sure that you power off your phone completely and disconnect from any external power source.
Was du brauchst
Use a T4 Torx screwdriver to remove the four 4.2 mm screws securing the lower case.
Gently pry the case open with a halberd spudger if the case will not release after removing the bolts.
Raise the cover without straining the connected ribbon cable.
Disconnect the ribbon cable from the motherboard with a halberd spudger.
Use a halberd spudger to lift the three flat-top connectors straight up to disconnect them.
Flip the motherboard over so the battery is facing upwards.
Gently pry the battery out of the motherboard housing.
Disconnect the battery ribbon from the motherboard using the spudger tool.
To reassemble your device, follow these instructions in reverse order carefully.
Eine weitere Person hat diese Anleitung absolviert.
3 Kommentare
Excellent guide, thanks. Any luck in finding a replacement battery?
Same. No idea where to get a replacement battery
