Zum Hauptinhalt wechseln
Motorola Moto 360 3rd Gen Charging Coil Replacement
Was du brauchst
  1. Motorola Moto 360 3rd Gen Charging Coil Replacement, Lower Case: Schritt 1, Bild 1 von 2 Motorola Moto 360 3rd Gen Charging Coil Replacement, Lower Case: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Halberd Spudger
    $2.99
    Kaufen
    • Use a T4 Torx screwdriver to remove the four 4.2 mm screws securing the lower case.
    • Gently pry the case open with a halberd spudger if the case will not release after removing the bolts.
    • Do not remove the lower case completely yet; this could damage cables connected to the lower case.
  2. Motorola Moto 360 3rd Gen Charging Coil Replacement: Schritt 2, Bild 1 von 1
    • Raise the cover without straining the connected ribbon cable.
    • Disconnect the ribbon cable from the motherboard with a halberd spudger.
  3. Motorola Moto 360 3rd Gen Charging Coil Replacement, Charging Coil: Schritt 3, Bild 1 von 3 Motorola Moto 360 3rd Gen Charging Coil Replacement, Charging Coil: Schritt 3, Bild 2 von 3 Motorola Moto 360 3rd Gen Charging Coil Replacement, Charging Coil: Schritt 3, Bild 3 von 3
    • Gently wedge a spudger underneath the charging coil ribbon.
    • Carefully pry the charging coil up and remove it from the assembly.
  4. Motorola Moto 360 3rd Gen Charging Coil Replacement: Schritt 4, Bild 1 von 2 Motorola Moto 360 3rd Gen Charging Coil Replacement: Schritt 4, Bild 2 von 2
    • Place the new charging coil in the same orientation as the one previously removed.
    • Attach the charging coil ribbon cable to the watch motherboard.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 174
