Zum Hauptinhalt wechseln
Motorola Moto 360 O-Ring Replacement
Was du brauchst
  1. Motorola Moto 360 O-Ring Replacement, Rear Cover: Schritt 1, Bild 1 von 1
    • Set the watch face down on a flat surface.
    • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
    • Follow the instructions here to remove the back cover without force by using some needles in the right places:
    • Motorola Moto 360 Gehäuseverschlüsse Austausch
    • Then continue with step 5. Or don't use needles and just continue with the next steps.
  2. Motorola Moto 360 O-Ring Replacement: Schritt 3, Bild 1 von 2 Motorola Moto 360 O-Ring Replacement: Schritt 3, Bild 2 von 2
    • Gently slide the blue opening pick between the rear cover and the metal casing.
    • The rear cover is extremely fragile. Be very delicate when using the opening pick.
    • Work your way entirely around the rear cover.
    • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
  3. Motorola Moto 360 O-Ring Replacement: Schritt 4, Bild 1 von 1
    • Once the adhesive has been successfully loosened, gently pull the rear cover off.
  4. Motorola Moto 360 O-Ring Replacement, O-Ring: Schritt 5, Bild 1 von 2 Motorola Moto 360 O-Ring Replacement, O-Ring: Schritt 5, Bild 2 von 2
    • To get to the O-Ring, use the Jimmy to gently pry off the rear housing.
  5. Motorola Moto 360 O-Ring Replacement: Schritt 6, Bild 1 von 1
    • Pinch the green rubber O-Ring and slide it off of the watch.
    • The O-Ring is delicate and is easily severed. Use care around sharp objects.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 17-32, Amido Winter 2015 Mitglied von Cal Poly, Team 17-32, Amido Winter 2015
CPSU-AMIDO-W15S17G32
4 Mitglieder
18 Anleitungen geschrieben
3 Kommentare
Where can you get your hands on a replacement o'ring?!
James S - Antwort
I broke my o-ring. Any ideas where I could get a raplacement?
Simon Hölz - Antwort
i think you should not take the o ring. i was replaceing the battery without take the O ring
cahyanto emanuel nur - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 2,704
