Einleitung
Changing the wrist strap may be easier if the rear cover is taken off first, but removing the rear cover is not required and risks damage to the rear of your device.
Was du brauchst
Locate the spring-loaded pin that attaches the wrist strap to the watch.
There is a tiny groove on the end of the pin. This is where you will place the tweezers.
Use the tweezers to compress the spring-loaded pin so the strap can be removed.
12 weitere Personen haben diese Anleitung absolviert.
