Einleitung
Replacing the touch screen requires you to completely disassemble the device. Use caution when handling the shattered screen.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Was du brauchst
To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
Using the same plastic opening tool as in step 1, once again pry up on the edges of the plastic back cover.
Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
Gently pull up on the red and black power cable to lift the connector out of the motherboard.
Move the battery and cover away from the motherboard.
Use a heat gun or hairdryer to heat up the edges. This will loosen the glue so the screen can be removed.
Gently slide the metal spudger underneath the screen and pry it away from the backing.
Move the metal spudger under the digitizer and along the entire length of the phone to separate the screen from the adhesive.
Continue to heat and separate until the screen comes completely apart from the rest of the phone.
23 weitere Personen haben diese Anleitung absolviert.
