Einleitung
Use this guide to remove or replace a battery in your Moto E4.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
This guide can also be used to gain access to the SIM card slot and the micro SD card slot.
Was du brauchst
Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
With the phone face down, lift the battery up by the labeled tab and remove it from the device.
5 weitere Personen haben diese Anleitung absolviert.
